Your last generator Maintenance Run
   / Your last generator Maintenance Run #5,461
when my portable Westinghouse generator is running, is it charging the battery?
I have a Noco charger also, I think a 3 or 5, but it has the conditioning cycle at the end which is supposed to
help loosen deposits on plates and make the batteries last longer. Like cleaning the hull of a boat.
I wish one of the internet testing websites tested small battery chargers. It's surprising how long the old names stuck with old tech.
And many still do. Smart chargers are well worth the money. But I wouldn't throw away the old buzzbox if you need something
charged in a hurry. Three to four times a year I put the Noco on the gen battery for a couple of hours.
I'm not sure how a smart charger deals with AGM batteries other than charging at a different rate. Does anyone know if the final conditioning cycle
accomplishes anything worthwhile on AGM batteries?
particularly with those larger Generacs, bad battery, no go.
I wonder if anyone has used a Li-on battery in a household gen.
Dave, are certain battery types better for your much colder temps?
   / Your last generator Maintenance Run #5,462
your generator should charge the battery, you can check with a volt meter
a equalize charge is actually bad for an agm, and should not be apart of the charge profile
li-on needs special care for a cold weather environment, not something I would recommend for a Generator standby
   / Your last generator Maintenance Run #5,463
Portable generator batteries tend to be dead when needed, unless the gen came with a 120v charger, or you keep battery on a trickle charger. Standby units use a standard lead acid car style battery, and the generator charge system keeps it nicely topped off. you can use agm style batteries on the generac standby, but I personally dont see any benefit, as a properly charged lead acid will last 5-7 years and is way way cheaper.
   / Your last generator Maintenance Run #5,464
With U there.
I have an intelligent 1 amp charger permanently wired to my battery so it will always be fully charged.
Also since my generator is in my attached shed I made a 12 inch hole and have a large muffin fan installed to evacuate any escaped exhaust fumes.
My genny provides both 110and 220,( both usable while running), so the fan and an overhanging light make life easier.
The setup is then permanently wired to an approved manual switchover box.
LOL, the only thing missing is the human to operate my system which makes me the volunteer.
AGM will use a different charge profile, optimally.
Didn't quickly find the curves I was looking for, but something from Rolls:
AGM Charging
I still like Flooded Lead Acid (traditional olde school) batteries for what they are, re. $ vs. performance. Cold Winters, I've seen FLA batteries freeze - a buddy had an Oldsmobile with a frozen battery, but it still started his V6 - go figure.....
SAE 101..... alternators are temperature compensated for FLA...... voltage ramps up as temperature goes down (FLA need the higher voltage to charge properly). So... a properly charged FLA battery won't normally freeze, outside of a bad Siberian Winter..... AGM MIGHT tolerate low temperature abuse a bit better, but it's too expensive a test for me to play with.....
Some plug-in AC chargers may be temperature compensated, but that issue will be a factor in the charger having a Low Temperature Limit spec'd.
Older Li batteries have low temperature concerns, as compared to FLA. If you need your tools running at O Dark Thirty onsite, you don't leave them in your truck overnight up here in the dead of Winter.....
I'm not up on what they are using now, but NiCad was the workhorse battery in Telecomm for the longest time. Tough batteries, that could take a lot of abuse, and tolerated low temperatures pretty well too.
All the electronics on a modern vehicle can drain a parked car's battery pretty quick..... all those folks not driving much these days would be well served by getting some of the decent basic chargers we've been comparing on here lately....
Rgds, D.
Check the manual to be sure..... many portables don't charge the onboard battery. The ones I've noticed that charge - Hondas, and some of the big Generac portables (?).
I've still got reasonable upper body strength (wrt. age), and healthy shoulders, but even with that luck, I really appreciate how well designed the pull-start is on my 7kw Briggs. WAY easier to pull, than many smaller engines I've started.
Rgds, D.
   / Your last generator Maintenance Run #5,467
This is a slight tangent from generators but I think relevant so bear with me: Interestingly for whatever reason the 12V auxiliary battery charge profile on a lot of EV systems is useless to put it politely. Our Nissan leaf only briefly pushes the battery to 14.4V after "booting" the car, it then quickly drops to about 13.2V. With regular use this generally isn't a problem, but Leafs in particularly are very prone to sudden FLA battery dead syndrome... Particularly cold weather and when sitting for a while.
I think the main issue is that the system relies too much on coulomb counting via the current transformer and not enough on how much charge current is there at 14.4V.
During the last Covid lockdown here in NZ the Leaf (normally in daily use) wouldn't boot after I think it was only 5 days sitting. Reminded me to keep putting the trickle charger on it every six months for an equalisation charge :)
   / Your last generator Maintenance Run #5,468
Rgds, D.
My 4 year old briggs 6.5 kw portable starts nearly every time with 1 to 2 pulls, and also pulls easily. I use that one around property.
That's one thing I haven't looked at..... how exactly the 12v battery is charged while mobile in an EV.
Total guess.... they have the 12v batt on a "starvation" diet, so they can eek out marginally further distance in mileage tests....
Rgds, D
   / Your last generator Maintenance Run #5,470
On my Ariens EFI snowblower the engine does NOT charge the proprietary 7.2v battery (think first gen Makita stick battery) that is tucked
up inside handle. Must be charged with their proprietary charger. About the dumbest design I ever saw.
Why not just power the efi unit with 12V and have a regular battery?
The EFI Honda 389 is a real gem of an engine, and makes for a very expensive generator. I bet their system is 12V.
I thought the charging circuit were those little magnets around the flywheel.?
UNUSED (1) 5200# DROP AXLE W/ BRAKES (A54756)
UNUSED (1) 5200#...
2017 JOHN DEERE 75G EXCAVATOR (A52705)
2017 JOHN DEERE...
Sterling AT (A55301)
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2015 Jeep Compass Latitude SUV (A53424)
2015 Jeep Compass...
2013 Ford F-150 Pickup Truck (A55788)
2013 Ford F-150...
