Your last generator Maintenance Run
   / Your last generator Maintenance Run
Well, like it or not I did a 'maintenance run' today.
Power went off early AM and just came on.
The generator started up like a champ and I served hot coffee and toasts to the Mrs.
Other that freshening my gas I don't ever need to do maintenance runs.
I did however start up the tractor hoping the engine was still warm enough to start. It did.
(Mitsubishi need glow plugs more than other brands)
Life is good!
Keeping electrons flowing...... always good, but esp. up here in the Winter ! Happy Wife makes for a better day :thumbsup:
IIRC, you have an advantage Piloon - your local utility "helps" you a lot with your maintenance-run reminders ;)
Rgds, D.
   / Your last generator Maintenance Run #1,972
...... started with me wanting more RoundTuIts in my face...... to help get me moving on maintenance..... along the way, we've had some very interesting setups presented, and at least 1 or 2 maintenance snags come up that I wouldn't have expected......
Balky or dead engines are never fun, but one thing I always want to fire and run smoothly on short notice is a generator.
Rgds, D.
Completely agree. Thank you for getting thread started.
You're most Welcome.
Started with my Lousy Memory....... thanks to that :), I've gained 100x more out of this thread than I expected..... Thanks to All for the great information that has been posted here.
Esp. if you are faced with your first dead engine, it helps to know that you are not the first one down that road...... many good test and maintenance tips have been posted here....... not the least of which is realizing that with today's off-shore manufacturing economics, you can often buy a complete ready-to-go new carb for not much more than what a carb-kit goes for !
As I type that last paragraph, I'm thinking......"Get that RoundTuIt Done to better organize my Parts Storage, then just buy 2 complete carbs (one large, one smaller portable gen in my case) and have them on The Shelf"...... Food for thought....
This thread does perpetually seem to create work..... :D
Rgds, D.
   / Your last generator Maintenance Run #1,974
A couple of unscheduled "tests" yesterday.
First one lasted a couple of minutes, later in the day the second one lasted about a half hour or so. The whole house generator kicked in as designed each time, only about 20 seconds of no-power each time (I forget the exact spec). With the various UPS units in place around the house there was no interruption on sat. TV, house WIFI or the 3d printer that was running a job during both events. No knowledge of what caused the outages. The second event had the wife smiling about how nice it was not to have to worry about when power would be restored & quite happy we spent the money..
On a different generator note, I finished up setting up the Champion 7K dual fuel with quick connects for the propane feed. Leaving the provided hose w/regulator attached had me worried about breakage when moving the unit around & removal between uses had me concerned about the flare fittings eventually leaking from repeated install/removal. The only pain was getting/building adaptors between SAE flare connections (on the gen & extension lines) & NPT (what the quick connects use). The original line & generator got one set and the extension hose got the second one. I already have a two bottle manifold set up for extended/high consumption use if needed. I keep 7 20lb bottles in the shed for "just in case".
It's great when a plan works out as intended ! AND, the wife likes ! Double bonus points :thumbsup:
Fittings/lines don't like impacts...... good point about converting to quick-disconnects.
"When you get a minute" :) ..... pics of those quick disconnects please ? Inquiring minds want to see exactly what they look like......
Rgds, D.
   / Your last generator Maintenance Run #1,976
Thanks Nik !
Rgds, D.
   / Your last generator Maintenance Run #1,978
So in this vein.... when should I replace the battery in my generator? It is electric start portable. It is 5 yrs old at this point and has the original battery. Last maintenance run at thanksgiving it fired up like it was new. It is on a battery maintainer 24/7. However I don稚 want to tempt fate....
   / Your last generator Maintenance Run #1,979
no one can answer this but you, if you can't take a SG level from the battery there really is no way to tell the health. that said can you pull start it? can you get the battery locally? you have to decide. battery's can die at any moment, they don't always show signs especially seldom use ones.
   / Your last generator Maintenance Run #1,980
My generator auto starts once a week for maintenance, but a couple days ago the Mate kicked it on because my batteries were down to 75%. It would run for a minute then shut off, run a min and shut off, again and again.
Upon checking the Mate for error messages, it kept saying “low voltage” - 76 vac to be exact. I thought my generator was dying (only 3 yrs old), but my neighbor said to let it run a couple minutes before engaging the charger. Then it worked fine. It has been rainy and cold and he said the humidity was wreaking havoc with the electronics until it is warmed up. So I set the timer on my Mate to engage the generator after 2 minutes of run time instead of 30 seconds. Seems to be working fine now.
Dump bed (A51692)
Dump bed (A51692)
(NEW) 2022 Greenworks CU400W Commercial Work Utility Vehicle (A55302)
(NEW) 2022...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
