Just a couple of things'
1. The engine on my generator started to vibrate apart at the engine case at about 100 hours of use. Fortunately I saw the puddle from loosing near a 1/2 quart of oil before the motor seized. I used a die grinder to give me access to the fasteners through the generator housing adapter to tighten things up. ( a very poor design!
2. Low oil sensor should have stopped the motor. Must have to be really low. Don't trust them!
3. Low oil sensors can indicate and also be ruined by moisture condensation in the oil and crank, so change oil yearly, even if oil is clean. Water is a poor lubricant.
4. Keep generator away from grinding dust.
Good points Mike, esp. re oil/sensors.....
What engine manufacturer ? Approximate size/hp ?
Rgds, D.
