You need balast or you will trash your front axle!!!! really?
   / You need balast or you will trash your front axle!!!! really? #251
I'm afraid this thread is testimony to the poor education system in the U.S. for at least the last 50yrs. (in both basic physics AND descriptive writing) :confused3:
(and I fully admit I have trouble writing clearly enough in this format to prevent SOMEONE from misinterpreting me)
   / You need balast or you will trash your front axle!!!! really? #252
+1....:thumbsup:
Agree. I definitely have writing issues. That part of my brain doesn't work.
   / You need balast or you will trash your front axle!!!! really? #254
Not being "educated" I must apply logic.
The FEL mount on a tractor is midship for the same reason it's at the rear of a SS. If you want the bucket located relatively close to the front of the tractor, rather than 6 feet farther forward, and you want to retain the ability to lift the bucket to an acceptable height, the mount point must be moved rearward on the tractor.
I contend that is the primary reason for location of any loader mount. The resulting influences are because of physics or mathematics or whatever "educated" term you wish to apply. :)
   / You need balast or you will trash your front axle!!!! really? #256
You are not alone, whether others admit it or not. I remember working out similar problems in structures class in college but that was forty years ago. While I have a vague idea of how to sum up the forces and reactions I don't know enough to teach it to others in a clear and concise manner. The engineer that commented earlier in this thread is correct, you have to solve the problem with a sum of the moments about the axles both clockwise and counter clockwise to get the answers. He was promptly jumped on and has not commented further, I don't blame him.
I was hoping that someone would eventually post an example with the necessary equations to resolve a sample problem but that hasn't materialized yet or I missed it.
   / You need balast or you will trash your front axle!!!! really? #257
From the operating manual for the Hurlimann
Maximum Loads Admissable on Tractor:
Front max 1000 kg
Rear max 1400 kg
Total 2100 kg
Must be the new math... ;-)
I don't think that is unusual, the 2100kg load can be a result of other factors such as brakes and ability to stop, engine power, steep grades and many others.
Not any different than a pickup truck.
Look at your door sticker. It will have GAWR for both front and rear. And then a total GVWR. If you sum up the GAWR's, it will be more than the GVWR.
My dodge 3500 has a front axle rating of 5200 and a rear of 9350......and a total GVWR of only 12,200.
   / You need balast or you will trash your front axle!!!! really? #258
"You need rear ballast or you will trash your front axle"
Highly unlikely. You'll blow the tires off the rims WAY before you damage any axle component. I've done it literally 100 times (before I finally put in tubes).
   / You need balast or you will trash your front axle!!!! really? #259
I tried tubes in mine......hate them. Too many thorns and flats. A thorn guard sealer (like slime) works alot better on a tubless tire as there is thicker material for the sealer to adhere to and work.
One of these days, I am gonna get the fronts foam filled.
   / You need balast or you will trash your front axle!!!! really? #260
I guess if you have a low tire or you run to low of pressure in the tires that might be true.
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 Ford F-550 4x4 Crew Cab Utility Flatbed Truck (A55973)
2019 Ford F-550...
(NEW) EXPEDITION 370 CROSS BOW (A58374)
(NEW) EXPEDITION...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
