You Know You Are Old When
   / You Know You Are Old When #6,901
I still have a lot of selenium rectifiers. All different sizes, some full wave, assorted voltage and current ratings.
Last week end, I halped a friend repair his standby generator set. An old "power company" Onan with a nice diesel engine.
It was only putting out 70 volts per leg.
It's a transformer regulated device, and a look at the schematic showed that the most likely, or at least the lowest hanging fruit would be the bridge rectifier that supplies the exciter. Sure enough, replacing that device brought the output to just under 250V leg to leg.
My friend was amazed that I happened to have such a component "just kicking around" in my shop. ;-)
   / You Know You Are Old When #6,902
It's been over 50 years since I had some Electronics Engineering but from memory () I seem to remember the forward voltage drop for germanium was about 0.3V, silicon about 0.65V, and selenium about 1 volt per stack. So I would replace a defective selenium with silicon for many reasons.
   / You Know You Are Old When #6,903
I've contemplated making a DC output for my ANCIENT buzz box welder.
But have not yet found a problem that AC stick could not handle. Barring TIG needs!
MANTLE & CHIMNEY FOR FIREPLACE (A58374)
MANTLE & CHIMNEY...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2011 DOOSAN G25KW GENERATOR (A58216)
2011 DOOSAN G25KW...
2002 Kenworth T300 TMA Attenuator Truck (A55973)
2002 Kenworth T300...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2000 Cummins DGDB 100kW Standby Diesel Generator (A56857)
2000 Cummins DGDB...
