You Know You Are Old When
   / You Know You Are Old When #5,251
Where as, once I dump 30 gallons in my cube I'm good for 6-8 months of fuel. My electric pump on the cube pumps 12 gallons a minute, so it takes no time or effort to fuel my tractors. Filling the 30 gallons of cans at the gas station and dumping in my cube, probably takes a total of 22 minutes of my time.
Hey, whatever works for you!
I've got arthritis, but it's mostly knees and fingers so huffing a 5g can onto the hood isn't a big deal (yet). When my tractor gets down to ~1/8, it's just about 5g to fill it so storing in that size container makes sense.
   / You Know You Are Old When #5,252
It would be nice to get diesel twice per year, and not replace cans every 5 years the way that I do now.
One of my 2 already has a bubble between layers in the plastic.
Do you store them outside? All of mine (2 5g diesel, a 5g kerosene and several 2 & 5g gasoline are all close to 20 years old and still in good shape.
   / You Know You Are Old When #5,253
They are sometimes in the sunlight. What caused the bubbles though, was when the sides sucked in due to cold temperatures.
   / You Know You Are Old When #5,254
In my case, 50 gallons. I use 2 quarts per operating hour.
That's believable, and for all I know, mine might be nearly the same. I honestly don't keep track of what the tractor uses, it's so much less than my ZTR mower.
But I don't think it changes my point that a 5 gallon can plus whatever is in the tractor itself, represents quite a bit of storage time at the rate most of us are using fuel, for those not earning their living on their tractor(s).
Quick math: My tractor tank holds 6-7 gallons, and I never really let it dip much below 1/4 tank, or 2 gallons in the tank. When I fill it from my 5 gallon can, I put the 5 gallon can in the back of the truck to refill at my next fuel stop. So, I usually have at least 7 to 12 gallons of diesel on-hand, which even at your 50 gallon/year usage, is 7.3 to 12.5 weeks worth of fuel! I don't need to store fuel longer than 7 - 12 weeks.
I understand the appeal of alternate solutions for those no longer able to lift a 5 gallon fuel can. But I hope it'll be a few more decades before I'm there.
   / You Know You Are Old When #5,255
I got news for all you young bucks, once you hit 80 the 5 gal containers are starting to get heavy and by the time your my age, 86 it's just easier to put in 3 or 3 1/2 gal when I get gas. I have no problem pouring that into the mower.
For diesel I generally get 5 gal at a time and have a wagon to haul it from the truck to the shed and a pump to fill the tractor never lifting more than from the truck bed to the wagon.
I can no longer lift 5 gal of diesel chest high and pour into the tractor, I bought the pump when I was 82.
   / You Know You Are Old When #5,256
I admit I am getting old, I gave up on 5 gallon jugs a long time ago. I burn thru 30 gallons a month during mowing season, if not more. With 3 tractors, a ZTR, and a UTV, all diesel, it goes pretty fast. The WM75 tank holds 20 gallons and burn thru it at about a gallon an hour. That is why I went with a 58 gallon tank and pump on a trailer. Much easier to fuel everything and refill the tank. The only gas motor is the small Honda on the pasture vac. For that I have a 1 gallon can of gasoline.
   / You Know You Are Old When #5,258
I filled one of my two 5 gal gasoline cans yesterday. I haul it in the bed of the pick up, tied down with Ancra straps.
It's pretty light when it's empty ;-)
I left it in the bed overnight, as I parked in the car park rather than pulling into the shop area and the shed where I keep the fuel cans (I keep two 5 gal diesel, and two 5 gal kero, and an assortment of 2 gal jugs for mowers, and two stoke mix.)
So I needed to go to a dentist appointment this afternoon, and grabbed the 5 gal jug out of the pickup and felt it's weight not so daunting. Puffing out my chest, I started down the steep grassy slope to the shed with the jug in hand.
Sure enough, something didn't go right, and I tweaked a knee. I got the jug to the shed alright, but now my knee is barking at me.
I sure wish my body could keep up with what my mind thinks I am.
73 and counting.....
   / You Know You Are Old When #5,259
According to this
there is no minimum age to be Pope and the youngest one was 18.
This from AI:
AI Overview
Learn more
The average age of the last 17 popes at the time of their election was 65 years and 2 months according to La Croix International. This suggests that assuming the papacy is generally a role assumed at a mature age, typically starting in one's 60s.
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
2012 DIAMOND C 40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2000 Mack CH13 (A56435)
2000 Mack CH13...
