You have gotta see this .
   / You have gotta see this . #2
Wow!!!!!!! I have been lucky, everytime I think I know what is safe you find a new to scare me. I have heard the whistle from the heat with the valve steme removed many times but never again. Thanks for the post.
   / You have gotta see this . #3
OMG!!!! did he say 22 hrs later? :shocked: If that's true, then what's to say the tire you're standing next to didn't get hit by lightning lastnight?
   / You have gotta see this . #4
Man! I've never heard of that, thanks for the link Iron Horse.
I have seated tire beads by spraying carb cleaner inside the rim and lighting it, but I had no idea of the danger.
I wonder why drag cars don't have this problem? There is alot of heat generated from doing a burnout.
   / You have gotta see this . #5
Scary stuff. I never thought about it to be honest.
I went to trade school with a guy that had a split rim bow up on him. It almost killed him. Split his head open so i knew the dangers of a tie blowing when being seated , but i didnt think about the dangers from excessive heat.
Thanks for the eye opener.
   / You have gotta see this . #6
I would think most of the heat from a burnout is left on the pavement. This demonstration seems as if the heat introduced to the metal of the wheel can't escape.
It's just hard to believe that heat would re-seat the bead in some cases. We had a company vehicle's hub cease up pretty bad...just wonder if that could have been real bad for the guys.
   / You have gotta see this . #7
I looked up the SADT (self accelerating decomposition temperature) for the material used in tires. It's 185 deg.C (365 deg. F).
Doesn't seem like much to get the chemical reaction in the tire going.
   / You have gotta see this . #10
Pyrolosis! That's crazy, never imagined that, even deflating or breaking the bead is not enough to prevent it?
I would never heat an inflated tire, since I almost blew my head off from cutting a pressurized vessel with a torch, I have "pressure vessel exploding phobia" but I would think deflating the tire would be enough of a precaution, I guess not.
Thanks for the safety warning.
JB.
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2017 JOHN DEERE Z950M LOT NUMBER 86 (A53084)
2017 JOHN DEERE...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
