york rake behind a jeep
   / york rake behind a jeep
More detailed idea:
12volt horizontal pump similar to one on surplus center part# 9-7413 for a dual acting cylinder mounted behind the rear seat. Then affix a cylinder from the top of the rather beefy bumper I have on the Jeep to the top mount of a Land Pride rake. Letting the two lower points act as the hinge. I chose this a possible option of how perfectly the height of the rake and bumper line up for welding the attachment points and bracing.
If the above seams plausible the parts I could use even more recommendations on are;
-Solenoid or lever?
If possible a solenoid controlled joystick, so I would only be running wires to where I would like to mount the joystick.
-Having the ability to 吐loat is also essential.
-Down pressure would be nice
-Check valves for holding in the up position
-Cross tube cylinder ends would appear to fit rather easily into the upper mounts of the rake. Would running spherical rod ends be more forgiving?
-Land Pride model 1560 Rake weighs 241 pounds
Thanks for all the help!!!
   / york rake behind a jeep #12
More detailed idea:
-Solenoid or lever?
I've always thought the Monroe lift was modeled off of a Ford 8N tractor. You can see the parts here http://www.farmjeep.com/img/lifts/monroe/Monroe Hydraulic Lift Parts List.pdf I had even thought about going to TSC and buying the replacement arms and links, but then found a complete lift. I wonder if you could do a modern version of the Monroe lift that would slide in/out of the rear, with a 12v hydraulic pump?
Only reason I was thinking stratton style was to retain the use of the back seat and storage area. The jeep is a big ugly salvage title, but perfectly safe and and legal to drive down the road serving many other purposes as well. You might be starting to sway me though I am off to my old jeep shop for some other parts and have printed some of your items on the monroe lift.
After I decide on the system I am going to use would the people in the hydraulics thread be able to point me in the right direction on a modern 12 volt pump.
Thanks for keeping the ideas flowing.
   / york rake behind a jeep #14
During the early 60's my dad helped a co-worker do a truck garden behind his orchard. The guy had a Farmall cub which had a plow and cultivator set. He had a tow behind disc set that was too big for the cub so they pulled it w/ his old flat fender willys jeep. They also used the jeep to pull the potato digger too. It wasn't a 'farm' jeep...
I had a '62 CJ5 w/ the PTO mount covered w/ a plate and the round hole thru the cross members for the PTO shaft. Any Jeep w/ the twin stick transfer case [in/out & HI-N-LO] was able to have a PTO.
I remember seeing a guy w/ a farm jeep and sickle bar cutting fields along the highway in the 70s...
   / york rake behind a jeep #15
What does the PTO do on a york rake?
Dean
   / york rake behind a jeep #16
We like the Newgren for the same reason of keeping the bed open. I didn't ask the year of the jeep, but if there is room under the bed, the underbed design is the way to go. I had a guy borrow the Newgren to have a copy made. It is a pretty simple construction. You can't tell it from the original.
The hydraulic forum is a great place to go for advice.
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2000 INTERNATIONAL 4900 CAR HAULER (A58018)
2000 INTERNATIONAL...
78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
78in Dual Cylinder...
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
(INOP) CHEVROLET C-50 GRAIN TRUCK (A52708)
(INOP) CHEVROLET...
