Rotary Cutter Yoke Removal - SQ720
   / Yoke Removal - SQ720 #1
MOTractor
Marshfield, MO
Ford 1920 FWD
Long time reader and lurker, first time poster.
I have a leaky Bush Hog Rotary Cutter - Squealer Series SQ720 - I do not have the clutch version. I have the two oil seals I need, but I am not sure how to remove the PTO shaft, have never done this before. There is a pin that sticks out 1/2" on one side and is "Peened" in on the other. Pics below. Do I pull or drive this out? The parts book calls it a "push pin set", i think it is part number 76062. My gear box is #71282. I think I have drive shaft #76737 or #76977 - looks like both use the same pin.
Thanks for the help!
   / Yoke Removal - SQ720 #2
I had a question about my Bush hog brand cutter about a year ago. I called the company direct and they put someone on the phone that was very helpful. You might try that.
I should have had more coffee before posting my question. Just got back from the barn, I used a small hammer and gently gave that "pin" a tap, which loosened up a decade of grease and grime - push the pin and the yoke / shaft slides off.
   / Yoke Removal - SQ720 #4
Good deal.
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
SCALES, PEA & BALANCE BEAM SCALES (A58374)
SCALES, PEA &...
LOT: (2) Komatsu Part # 207-70-73210, (2) Komatsu Part # 208-70-73220 (A59076)
LOT: (2) Komatsu...
