YM2500 - Hydraulic Ports
   / YM2500 - Hydraulic Ports #1
Abee
Lake Country, Missouri
YM 2500
Can someone identify these hydraulic ports and tell me how they are used? Also what is knob "D" used for. Is one port "high Pressure" and one "Return". If so could I add quick-connect couplers for add-on hydraulic equipment? See attached .BMP image. /forums/images/graemlins/confused.gif Thanks,
   / YM2500 - Hydraulic Ports #2
"A" can be used as an outlet port. The 3 poimt control lever will operate a single acting cylinder. To operate a double acting cylinder , the 3 point control lever will have to be up & a double acting control valve & a shut off will have to be installed with the "out" going to the rear end housing. When using the 3 point, the shut off will need to be closed. This isn't the way I'd recommend installing remotes. Go to http://groups.msn.com/SheaffersTownCountryTractors/general.msnw?action=get_message&mview=0&ID_Message=10&LastModified=4675442816712253488 for remote installation.
"B" is a cap for the control valve guts.
"C" is the cap for the piston relief valve.
"D" is the 3 point position lock.
/forums/images/graemlins/laugh.gif ThankYou!!! This is exactly what I needed to know.
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53473)
GOODYEAR SET OF...
Hand Truck (A52377)
Hand Truck (A52377)
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
2018 Kubota RTV-X1100C 4x4 Diesel Utility Cart (A51694)
2018 Kubota...
Vermeer Chipper BC900 (A52377)
Vermeer Chipper...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
