YM2500 - Hydraulic Ports
   / YM2500 - Hydraulic Ports #1
Abee
Lake Country, Missouri
YM 2500
Can someone identify these hydraulic ports and tell me how they are used? Also what is knob "D" used for. Is one port "high Pressure" and one "Return". If so could I add quick-connect couplers for add-on hydraulic equipment? See attached .BMP image. /forums/images/graemlins/confused.gif Thanks,
   / YM2500 - Hydraulic Ports #2
"A" can be used as an outlet port. The 3 poimt control lever will operate a single acting cylinder. To operate a double acting cylinder , the 3 point control lever will have to be up & a double acting control valve & a shut off will have to be installed with the "out" going to the rear end housing. When using the 3 point, the shut off will need to be closed. This isn't the way I'd recommend installing remotes. Go to http://groups.msn.com/SheaffersTownCountryTractors/general.msnw?action=get_message&mview=0&ID_Message=10&LastModified=4675442816712253488 for remote installation.
"B" is a cap for the control valve guts.
"C" is the cap for the piston relief valve.
"D" is the 3 point position lock.
/forums/images/graemlins/laugh.gif ThankYou!!! This is exactly what I needed to know.
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
1985 FREIGHTLINER FLC DUMP TRUCK (A53843)
1985 FREIGHTLINER...
BUYERS PREMIUM & PAYMENT TERMS (A54607)
BUYERS PREMIUM &...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53473)
2018 John Deere...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
