ym2500 alternator rating
   / ym2500 alternator rating #1
tmar04
YM 276
could someone tell me the output, maximum, in amps for the OEM alternator on Yanmar YM2500? I had mine rebuilt, works fine, just need specs on it for installing additional lighting. thanks to all.
   / ym2500 alternator rating #2
15 Amp.
Danny
thanks, Danny. Wow! not really much, is it? Terry
   / ym2500 alternator rating #4
No, it's not much. The charging system on these units wasn't designed to do anything beyond re-charge what was lost in starting. We find the output on most units actually measures closer to 14. You can kill a battery with enought starts followed by short run times.
   / ym2500 alternator rating #5
"The battery should be fully charged using a regular charger at least once a month." Source: Operation Manual, YM240.
I run HF's little $4.99 charger overnight if the tractor hasn't been started for several days and dormant voltage shows 12.6 or below. This seems to work; the last battery made it past its eighth birthday.
   / ym2500 alternator rating #6
We strongly encourage customers to start their tractor every couple weeks and just ride around if nothing else. We use some trickle chargers here, and I just ordered our first smart charger....the new, seemingly really nifty technology...to try. Even a good trickle charger can overcharge if left on continuously, and supposedly the smart chargers don't do that.
   / ym2500 alternator rating #7
... and the cheap ones will cook the water out, even if the voltage never exceeds 13.3.
I used to leave the $5 charger on when I would be away for a few days. After a year of that, the battery water level was way down into the plates. I switched to checking it with a voltmeter and charging only when needed.
A 'smart charger' would do this for you automatically.
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2012 JOHN DEERE 644K WHEEL LOADER (A52705)
2012 JOHN DEERE...
GENERATOR (A53843)
GENERATOR (A53843)
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
40ft Sea Container (A52384)
40ft Sea Container...
