ym2500 alternator rating
   / ym2500 alternator rating #1
tmar04
YM 276
could someone tell me the output, maximum, in amps for the OEM alternator on Yanmar YM2500? I had mine rebuilt, works fine, just need specs on it for installing additional lighting. thanks to all.
   / ym2500 alternator rating #2
15 Amp.
Danny
thanks, Danny. Wow! not really much, is it? Terry
   / ym2500 alternator rating #4
No, it's not much. The charging system on these units wasn't designed to do anything beyond re-charge what was lost in starting. We find the output on most units actually measures closer to 14. You can kill a battery with enought starts followed by short run times.
   / ym2500 alternator rating #5
"The battery should be fully charged using a regular charger at least once a month." Source: Operation Manual, YM240.
I run HF's little $4.99 charger overnight if the tractor hasn't been started for several days and dormant voltage shows 12.6 or below. This seems to work; the last battery made it past its eighth birthday.
   / ym2500 alternator rating #6
We strongly encourage customers to start their tractor every couple weeks and just ride around if nothing else. We use some trickle chargers here, and I just ordered our first smart charger....the new, seemingly really nifty technology...to try. Even a good trickle charger can overcharge if left on continuously, and supposedly the smart chargers don't do that.
   / ym2500 alternator rating #7
... and the cheap ones will cook the water out, even if the voltage never exceeds 13.3.
I used to leave the $5 charger on when I would be away for a few days. After a year of that, the battery water level was way down into the plates. I switched to checking it with a voltmeter and charging only when needed.
A 'smart charger' would do this for you automatically.
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53473)
Chevrolet C8500...
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
1999 LinkBelt HTC8650 50 Ton Crane Boom Truck (A53117)
1999 LinkBelt...
Ammco Brake Machine (A53424)
Ammco Brake...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
