YM240D Loader Controls
/ YM240D Loader Controls #1
Rogerrl
I have a YM240D with a Yanmar 240 loader. Had the hoses changed to the loader control spool. Now it seems different than it used to. I cant remember what it did when which lever was moved. All I can remember is inside lever moved bucket and outside did boom. Does anyone know what should happen with each lever. IE inside lever when placed forward should bucket curl up or dump?
Outside lever pushed forward, should boom go up or down?
/ YM240D Loader Controls #2
On my YM240:
Inside lever: Pull, lift. Push, down. Push some more, float.
Outer lever: Curl back, curl forward.
I thought this configuration was industry-standard. But I've been wrong before - as some of the regulars here will point out if I don't. :D
/ YM240D Loader Controls #3
(QUOTE California) But I've been wrong before - as some of the regulars here will point out if I don't.
Hold on there Now Cal. That would be me of bad advice and being wrong. Esp. on the Ym2000/240's. just ask the
Hini motoman :shocked:
OK this has gotten more complicated. My outside lever when pulled has boom go down, then when pulled further goes into float. So it would appear my machine is backwards.
/ YM240D Loader Controls #7
Is it possible your whole control valve got turned around, sounds like it would be like California's if it was turned around. Not sure what difference all this makes unless it's just something you are used too.:thumbsup:
/ YM240D Loader Controls #8
I have the same tractor and the loader operates identical to California's. Sounds like maybe the hoses got shuffled around during replacement?
/ YM240D Loader Controls #9
If his hoses got shuffled the float would still be different or am I thinking crooked? Still sounds like valve turned around.:confused:
/ YM240D Loader Controls #10
Agree.
If float was in upper left and now is in lower right, the only way this could happen is if the control valve was rotated 180 degrees before it was bolted down.
/ YM240D Loader Controls #11
Sounds like he's not sure which was up and which was down, but I'll bet the hoses just got switched from the way they were, no reason to mess with the valves on a hose replacement.
/ YM240D Loader Controls #12
Norm, I think it would be confusing to leave Float at right-pull. I think the valve has to be physically moved to remedy this, since Float is an actual set of passages drilled at one end of one of the valves.
2012 CHEVROLET SILVERADO 3500HD CC (A67714)
2012 CHEVROLET...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A69167)
2005 MACK CXN613...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
