YM226D Won't come out of 4WD
   / YM226D Won't come out of 4WD #1
JIMTORL
SE PA and Eastern shore MD
Dane z drive, XMark Z, Yanmar 226D,Kubota B3030
YM226D Won\'t come out of 4WD
I looked at a YM226D today. Looked good and ran good until I noticed it was in 4WD. I asked how to take it out and the guy told me the lever was broke it just flopped back and forth.
He told me it was a was an eazy fix and common in Yanmars for this to happen but he was to busy to do it. I think this guy was lying to me by the way he was acting. So what do you guys think it would cost and is it a major repair?
He also told me he bought it new I thought this was a gray market tractor but I could not find this model number.
Thank you for your input
   / YM226D Won't come out of 4WD #2
Re: YM226D Won\'t come out of 4WD
Check this post about 4 wd repair. It may help 4 WD look at the reply from Hoye tractor & click on the linc.
   / YM226D Won't come out of 4WD #3
JIMTORL,
YM 226D, nice tractor. Made for America, not a grey market tractor. Either a roll pin or shaft as indicated by Kenmac and his reference to previous post.
Regards, Mark
   / YM226D Won't come out of 4WD #4
ditto on what the other folks said. and, btw, it's nice tractor, let one pass by and sorry that i did..
and, also, btw, having 4x4 working is less of a problem than not having it working!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Does anyone know what the HP is on this tractor?
   / YM226D Won't come out of 4WD #6
JIMTORL:
22hp?????...
   / YM226D Won't come out of 4WD #7
226D, nice tractor 22 hp, about 18 or so on the pto, build for US market, parts are no problem. 4wd problem is not uncommon, more then likely only a 20 cent rollpin, about the only other thing it could be is the gear actuator linkage inside, that can be welded or bought for about $ 50 had the same problem on mine, ended up being the linkage. About the only bad thing about that is that it means draining all 5 gallon of hydrolic fluid, but probably be a good idea to change that anyway.226 is a nice tractor, right size, right amount of power for general use, don't let it slip away, you will be sorry later
pete
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
CRESCENT  MANIFOLD TRAILER (A53843)
CRESCENT MANIFOLD...
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
