YM2210 - when & where to grease
   / YM2210 - when & where to grease #1
heitjer
Houston, TX
LS R4041 & LL4100 FEL
Hallo All!
I need some advice. I have had my YM2210 for three month now and finally got a grease gun. I used all purpose grease as it was recommended by a local shop.
Today I greased everything that I could find including the FL. I noticed that I had nothing on the rear axle. Can someone please point me to the right grease nipple for this (I seemed to be blind).
Thanks!
   / YM2210 - when & where to grease #2
Don't think you need to grease the rear axle. It's lubed internally. You do probably have grease fittings under your foot rest areas where your brake and clutch petals pivot.
That explains my 'blindness' - I was just wondering why my axles squeekes in slow gear. That's why I wanted to grease it up again.
Is there something else I can do?
   / YM2210 - when & where to grease #4
I can't see it from here but would suspect the squeaking could be the brakes. Might take a look in that direction. I'm assuming you have checked your transmission fluid level.
Great tip - haven't thought about that. Thanks!
   / YM2210 - when & where to grease #6
I highly recommend one of these, especially for hard-to-reach places that need lube. Fill with 90wt, stand back 5'-10', and squirt. No need to climb/crawl all over the equipment. Will squirt a stream 10-15'.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A53843)
HYDRAULIC THUMB...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2019 GENIE GS-1930...
2013 FORD F-550 (A53843)
2013 FORD F-550...
2014 FORD FOCUS(INOPERABLE) (A53843)
2014 FORD...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
