Mowing YM2202, Engage PTO, let out clutch, stops the engine.
   / YM2202, Engage PTO, let out clutch, stops the engine. #1
Pinkylabmouse
Trinity, Al
YM2202
Yanmar 2202.
Engage PTO, let out the clutch and the engine bogs down and stops. It's like the gear box is frozen. The PTO will not turn. You can let the tractor move forward and grind gears trying to engage the PTO but it does not engage. Stop the tractor, engage the PTO, let out the clutch and the tractor bogs down and the PTO does not turn. I have a 4ft. woods finish mower attached at present.
Yours in Christ,
Pinkylabmouse
   / YM2202, Engage PTO, let out clutch, stops the engine. #3
Is the mower hooked up to the pto? Do the symptoms occur when there is no mower attached?
   / YM2202, Engage PTO, let out clutch, stops the engine. #4
I agree. Disconnect and check and see if the Drive shaft to the mower will turn. I'm guessing it won't.
Toro Workman 3200 Cart (AS IS) (A50774)
Toro Workman 3200...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
