Mowing YM2202, Engage PTO, let out clutch, stops the engine.
   / YM2202, Engage PTO, let out clutch, stops the engine. #1
Pinkylabmouse
Trinity, Al
YM2202
Yanmar 2202.
Engage PTO, let out the clutch and the engine bogs down and stops. It's like the gear box is frozen. The PTO will not turn. You can let the tractor move forward and grind gears trying to engage the PTO but it does not engage. Stop the tractor, engage the PTO, let out the clutch and the tractor bogs down and the PTO does not turn. I have a 4ft. woods finish mower attached at present.
Yours in Christ,
Pinkylabmouse
   / YM2202, Engage PTO, let out clutch, stops the engine. #3
Is the mower hooked up to the pto? Do the symptoms occur when there is no mower attached?
   / YM2202, Engage PTO, let out clutch, stops the engine. #4
I agree. Disconnect and check and see if the Drive shaft to the mower will turn. I'm guessing it won't.
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2010 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2010 Ford F-150...
Hobby Farm Manure Spreader (A50515)
Hobby Farm Manure...
2016 MACK CXU613 DAY CAB (A52141)
2016 MACK CXU613...
