YM2010 Transmission Screen Location
/ YM2010 Transmission Screen Location #1
ufengineer
Bronze Member
Jacksonville, florida
ym2010
Where is the transmission screen on a YM2010. Does anyone have a picture of a schematic?
/ YM2010 Transmission Screen Location #2
Does that machine have the Powershift transmission?
My YM240D (which is a standard geared tranny) has a screen that's accessed from below. There's a plate that can be seen when looking below the tractor from the front toward the rear. Remove the three bolts on that plate to reveal a removable screen.
/ YM2010 Transmission Screen Location #3
Here's a cross-section of my machine. Maybe that helps?
/ YM2010 Transmission Screen Location #4
Out of the 2010 manual.
/ YM2010 Transmission Screen Location #6
thats a power shift tractor , i am not sure if its the same as a 2000 or not. Onthe YM2000 its on the lower portion of the trans sump, faces foward and is behind a triangular but roundish plate with 3 bolts with about a 10-12mm head on them. It faces toward the front of the tractor.
/ YM2010 Transmission Screen Location #7
ok sorry i missed winstons post. Its one of those thats on the side of the transmission houseing.
I still can't find it. There is a circular plate with two bolts in it. I can't find a roundish triangular plate anywhere on the trains. Can someone post a picture.
/ YM2010 Transmission Screen Location #9
Look at the pic winston posted #26
/ YM2010 Transmission Screen Location #10
Bottom left (sitting in seat) of transmission housing. 3 bolt flange.
/ YM2010 Transmission Screen Location #11
Also, likely, directly opposite side of tractor than the hydraulic supply line to the hydraulic pump - the pump likely draws its fluid through the screen.
/ YM2010 Transmission Screen Location #12
ufengineer, I owe you an apology. I copied the wrong page. The one I copied was the 2210. Only difference is yours has the 2 bolt flange. Same place though. Sorry I mislead you. :ashamed:
Thanks Winston. This model has a cover with two bolts. The two vs three bolt cover is what was throwing me off. Apparently most models have a three bolt cover and only a few have a larger circular cover with two bolts. I was one of the lucky to have one with the latter.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2011 Ford F-750 Terex Hi-Ranger 5TC-55 55ft. Insulated Bucket Truck (A60352)
2011 Ford F-750...
8' DISC HARROW (A60430)
8' DISC HARROW...
