YM2000 - Volt. Reg.
/ YM2000 - Volt. Reg. #1
sls
Mississippi
YM 2000
Finally found the time to put on the 1972 Datsun 510 voltage regulator. Same plug and bolted right up to the frame. WORKS GREAT!!! Checked with a meter and it puts out 14.5v at the battery. Found a new one for $10.00 bucks including shipping (ebay). The old regulator was open to the elements and had a lot of dust... in there. Wonder if it can be cleaned and made workable. It was reading about 17-18v and I didn't want to damage the new battery.
/ YM2000 - Volt. Reg. #2
Did you try backing off the adjustment screw?
/ YM2000 - Volt. Reg. #3
My local parts store told me that the regulator from my 2210D was the same as an old datsun. New solid state one was less than $20. works great!
100 gal L Double Fuel Tank (A66408)
100 gal L Double...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
(8) John Deere Suitcase Weights (A65640)
(8) John Deere...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
