Ym2000 pto shaft seal/rear bearing
   / Ym2000 pto shaft seal/rear bearing #1
Bigd9116
Westover md
Yanmar
While removing the pto rear seal I found the bearing on the pto shaft in pieces. I removed rear cover plate and the entire gear system came out with it I removed the old bearing and believe I have everything sitting back in how it was but, when I stuck my hand in the bottom of the case to feel for parts I found one snap ring and an unidentified object if anyone can offer advice on where they may have came from? I heard one thing fall as I was sliding the gears out and believe it was the drive shaft and the coupler. Also on the back of the main cover plate there is two small bolts around the oil seal, they don't seem to be holding anything, it seems to me there should be a small plate that slides over the pto output shaft and holds the seal in? Thanks for advice here is the pic of the piece I found in the bottom of the case; well I don't know how to add a picture the piece is a small u shaped piece approx 10" long and 1/8" in diameter [______ kinda like that with a line on the top as well.
   / Ym2000 pto shaft seal/rear bearing #2
We will need a picture. Click the little picture in the reply box and find it on your computer and attach it.
I have not pulled the PTO unit before so i can not say and i dont have a picture but you can see a diagram on HOYE's page. I know someone here has a pic they can post, that person just has to be on here?
   / Ym2000 pto shaft seal/rear bearing #5
The big 'U' shaped piece goes inside of the hydraulic screen to hold it in position.
The seal is just a tight fit into the case. There is nothing else that holds it in.
   / Ym2000 pto shaft seal/rear bearing #6
This is the clip I was referring to. Relatively easy access. If it's there then rule it out. I had to replace my Screen/Filter so I new what that part was. It was pretty beat up also.
That is def the screen hold down, and it makes sense that the snap ring could be from the pto bearing as that was in pieces. Where does the filter go so I can check for the rest of it? Also, some of the drawings are hard for me to understand does anyone have the part number for the pto shaft bearing/race and snap rings closeat to the output shaft and the oil seal behind it? Also what type of oil do you recommend
   / Ym2000 pto shaft seal/rear bearing #8
Hyd. Screen is the Grn. Triangle. And the U from memory that is the inside of the filter. When you take the Tri. plate off your find out whats left of it. Probly not much so who knows what your find. Yanmar Tractor Parts HYDRAULIC SCREEN ASSEMBLY - IN STOCK!
I use JD-303 spec. Universal Trans Hyd. fluid. I pick it up at WallyWorld you need about 4.5 gal.
Thanks for the inform on the screen that is probably all the pieces I found, will the one u hyperlinked work with the ym 2000
   / Ym2000 pto shaft seal/rear bearing #10
yes thats the correct screen. I think there all the same?
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
20ft Driveway Gate (A51573)
20ft Driveway Gate...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
