YM2000 piston. I think I found my running and starting problem
   / YM2000 piston. I think I found my running and starting problem #1
mikereid
Jackson, GA
Yanmar YM1700
Here is a picture of the piston I pulled out of my engine today.
The rings looked really good but part of the piston was broke inbetween the top two rings.
I think this may be my hard start and lugging problem when taking off from start.
What are your opinions?
   / YM2000 piston. I think I found my running and starting problem #2
Ouch. where did the broken piece go ?
Was there a comp test done before tear down ?, results ?
   / YM2000 piston. I think I found my running and starting problem #3
you found the problem...were the pieces in the oil pan? How do the liners look?
   / YM2000 piston. I think I found my running and starting problem #4
Any pics of the cylinder wall?
The piece was still in between the rings, in place just loose.
There was no wall scaring at all. I could not believe it myself if I did not see it.
I did not do a compression check before hand.
   / YM2000 piston. I think I found my running and starting problem #6
that makes sense. I would still give the liners a once over. new rings and bearings and you should be all set.
   / YM2000 piston. I think I found my running and starting problem #7
I have reused bearing in a simlar situation. Don't forget the obvious, a new piston. :)
What ever you replace be sure to check the old part for any indication that they are not original size (eg a .010 mark on them) On the bearing it would indicate that the crank has previously been reground. On the piston, then the cylinder has been over bored. I think even the rings can be marked near the gap.
I forgot to check once and had sloppy bearing fit on reassembly.:eek:
   / YM2000 piston. I think I found my running and starting problem #8
Is it possible that the piston broke during dissasembly? The break and casting surface looks very clean to be broken for any extended run time....Just playing the devils advocate here.
Mark
The only reason I think it has was broke before I got it is that there is scoring on the side of the piston like it was pushed over to one side.
See the pics one of each side.
   / YM2000 piston. I think I found my running and starting problem #10
I broke one it looked just like yours when I didn't ream the ridge off the cylinder (young and naive) I just hammered it out. then I reamed the other 7on that motor and they slid right out and reamed then first to get new pistons back in.
tom
2012 JOHN DEERE 333D SKID STEER (A52706)
2012 JOHN DEERE...
2019 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2019 TOP HAT...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
ALLEN TRUSS SCREED (A53843)
ALLEN TRUSS SCREED...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
