YM2000 noise from PTO lever
   / YM2000 noise from PTO lever #1
pabluski
Greetings everyone. I have a YM2000 that I purchased 2 years ago. I'm concerned with a new noise coming from the PTO. I was bush hogging some terrain for a couple of hours, when it was time to put the tractor away I noticed that the PTO now made a grinding noise. I also noticed that I can not find the PTO neutral any more. If I press the PTO level towards the gearbox the noise subsides. I added hydraulic oil since it was one mark too low, but the noise did not go away. I was able to put the PTO in "neutral" between the 2nd & 3rd spot. What' going on here?
Thanks,
Pabluski
China Grove, NC
   / YM2000 noise from PTO lever #2
I can't tell you foor msure what is wrong. Best thing to do is remove the hydraulic lift housing & inspect the pto. It will ahve to be removed to fix it any way.
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Kuhn FC 4000 RG (A50123)
Kuhn FC 4000 RG...
TROY BILT PRESSURE WASHER (A51248)
TROY BILT PRESSURE...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2018 FREIGHTLINER...
