YM2000 noise from PTO lever
   / YM2000 noise from PTO lever #1
pabluski
Greetings everyone. I have a YM2000 that I purchased 2 years ago. I'm concerned with a new noise coming from the PTO. I was bush hogging some terrain for a couple of hours, when it was time to put the tractor away I noticed that the PTO now made a grinding noise. I also noticed that I can not find the PTO neutral any more. If I press the PTO level towards the gearbox the noise subsides. I added hydraulic oil since it was one mark too low, but the noise did not go away. I was able to put the PTO in "neutral" between the 2nd & 3rd spot. What' going on here?
Thanks,
Pabluski
China Grove, NC
   / YM2000 noise from PTO lever #2
I can't tell you foor msure what is wrong. Best thing to do is remove the hydraulic lift housing & inspect the pto. It will ahve to be removed to fix it any way.
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53472)
3-Point Hitch Root...
2023 WESSEX RMX500 LOT IDENTIFIER 44 (A53084)
2023 WESSEX RMX500...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2012 Buick Enclave Premium SUV (A53117)
2012 Buick Enclave...
