YM2000:Hanging left brake pedal
   / YM2000:Hanging left brake pedal #1
NCShelton
Monroe, LA
Yanmar YM2000
The left brake pedal on my YM2000 hangs when I use it - that is, it doesn't spring back like it should. I have greased the fittings on the shaft (both sides of the tractor), but it hasn't helped. There is a small plug at the bottom of the chamber through which the shaft goes to get to the other side. It was finger tight, and nothing drained out when I removed it. Is there supposed to be oil in it? It would make sense that there should be in order to lubricate the bushings on the brake shaft through it. If oil is needed, what kind and where do I put it in? If oil is not needed, how do I lubricat the bushings? Or, any other ideas on how to free up the left brake pedal?
Thanks,
   / YM2000:Hanging left brake pedal #2
It's likely brake dust jamming the brake shaft after it enters the rear axle assembly. You can verify this by unfastening the brake rod from the lever on that shaft.
You can't lube that shaft without disassembly because there is an o-ring to keep water out.
Loosen the fender and swing it back out of the way, then remove the brake enclosure cover to get that shaft out and clean it. About an hour for the whole project.
2015 Ford F-750 Liftmoore 2550 5,000LB 2.5 Ton Crane Mechanics Truck (A51692)
2015 Ford F-750...
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
2003 Chevrolet Silverado 2500HD Pickup Truck (A53117)
2003 Chevrolet...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
