YM2000 Alternator testing
   / YM2000 Alternator testing #1
Mslater
Baton Rouge LA
YM2000
Ok, I set my meter on ac and test which outputs? Thanks!
   / YM2000 Alternator testing #2
You want DC, put leads across your battery terminals, looking for +14vdc+- at high idle.
Thanks I'll check it out again!
I checked at the batt running at about 1500 rpm and get 12.3 volts. Now that I know its not charging how to I narrow it down? Whats the procedure to test the alternator seperately? Thanks alot for your help!
   / YM2000 Alternator testing #5
I'm not sure if your bridge rectifier is in the alternator or the regulator; however, you can unplug the regulator from the alternator and meter across the alternator post and look for +20+- volts on AC or DC scale. No voltage says bad alternator, +20+- says bad regulator, AC or DC reading gives the location of the rectifier, which changes voltage from AC to DC. It's usually a bad regulator.
Gotcha, I'll give it a shot tomorrow. Thanks again!
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2015 PETERBILT 389 (A52472)
2015 PETERBILT 389...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2015 Ford F-150 4x4 Crew Cab Pickup (A50323)
2015 Ford F-150...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
