YM2000 3PH won't stay set
   / YM2000 3PH won't stay set #1
gclark94560
UCLA - Upper Corner of Lower Alabama (Lanett)
Zen Noh/Yanmar YM2000, green
Hi All! I have a green YM2000 with the three control three point hitch system. I can't get my bush hog or box blade to stay where I set it. :mad:
The little drop rate adjuster on the right, under the seat, seems to work right. The big raise/drop lever on the right works, but it seems that there is very little if any "sweet spot" to it. It is either going up or down.
There is a T shaped screw in control in front of the seat. I have heard everything from leave it alone to it only works for locking the TPH in the up position. It seems like it sort of holds the TPH in place if I lock this down - real fast when I see I am where I want to be. Even at that, in a few minutes the hitch is all the way down.
What am I missing? Is it broke? Should I just go to gauge wheels? :confused:
Thanks!
   / YM2000 3PH won't stay set #2
It may have rust or debris on the hydraulic cylinder or the "0" rings have failed. If the hydraulic fluid has been changed and filter cleaned recently I would disassemble, inspect and clean the TPH hydraulic assembly.
Mark
   / YM2000 3PH won't stay set #3
Is the lever moving, or does it stay where you put it?
Hi All! Thanks for the replies. TBN is quite a resource!! :D
The hydraulic /transmission oil has been changed. None of the levers are physically moving - unless I accidentally bump the mail big TPH lever with my hip.
I am 5' 9" and 170 lbs. I don't see how really big people drive these things! :)
I will look into the o ring thing. I think Hoye has parts breakdowns on their site.
Greg
   / YM2000 3PH won't stay set #5
"None of the levers are physically moving - unless I accidentally bump the mail big TPH lever with my hip."
Are you sure that is not happening? that is usually the no.1 suspect for this problem, (whatever a "mail big" TPH lever) is.
   / YM2000 3PH won't stay set #6
Mark
I agree , The O rings found in this diagram most likely are bad , causing leak down. HYDRAULIC_LIFT: Yanmar Tractor Parts
normde2001 said:
"None of the levers are physically moving - unless I accidentally bump the main big TPH lever with my hip."
Are you sure that is not happening? that is usually the no.1 suspect for this problem.
Hi All!:rolleyes:
It has been a few months and guess who is right?? :D
It IS the lever moving. There is a small friction washer that works with a screw and nut and a tension spring. The fiber friction washer was worn to where there was a projection into the slot that the screw ran in and it was deep enough so as to allow very little friction. I replaced the washer and it works great!!!
Thanks!
Greg
   / YM2000 3PH won't stay set #9
Glad to hear that it wasn't the o rings causing the problems as the o ring replacment wouldn't have been as easy as the washer replacment
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
