YM187 Starts Poorly.....HELP!
   / YM187 Starts Poorly.....HELP! #1
TractorEd
Does anyone have any advise on what to look for on this little engine? It runs and starts fine after it warms up. When cold it just pops and farts. I used a salamander heater to warm it up and then it will start. I have already checked the glow coil in the intake manifold and it works well with fuel valve opening and igniting. Compression seems good (equal in all cylinders). Any help would be appreciated as the snow is piling up around here!
   / YM187 Starts Poorly.....HELP! #2
Have you checked out the fuel delivery system like filters etc.
How cold is cold?
Do you use a fuel addative?
Egon
   / YM187 Starts Poorly.....HELP! #3
during the popping and farting stage, any white smoke?
//greg//
   / YM187 Starts Poorly.....HELP! #4
My 180 was the same way when I bought it. It had been outside for a while and just needed a good going over. Make sure your fuel is clean. If it's cold, use an additive to increase cetane and prevent gel up. Check for leaks between bowl and pump. If fuel can get out, air can get in. After changing fuel filters and putting on new lines, I switched to road fuel (47 cetane) with Power Service additive, and the tractor started like a new one!!
Good luck.
   / YM187 Starts Poorly.....HELP! #5
The fuel and system must be good, but one of the most important things for easy starting is to be sure the valve clearances are exact. No matter how good your fuel is, the timing is critical. When each piston is at top dead center, the clearance should be .008".
Thank you for all your help! I'll let you know if I get it fixed! Merry Christmas everyone! /forums/images/graemlins/grin.gif
Set of Ag R4 Wheels and Tires (A53472)
Set of Ag R4...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2020 RoGator RG1300 Air Max Precision R2 Spreader (A53342)
2020 RoGator...
John Deere X530 (A51573)
John Deere X530...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
