YM1700..Hydraulic valve
   / YM1700..Hydraulic valve #1
Popstoy43
I just purchased this tractor and was wondering what function the hand valve under the seat controls. It is marked on or off.
Also I would like to run a hydraulic log splitter off of the tractor. Any tips or ideas on plumbing one in. Thanks. /forums/images/graemlins/confused.gif
   / YM1700..Hydraulic valve #2
Welcome to TBN,
The knob under your seat is the implement lock...CW will lock the hydraulics, and CCW will open and the implements will lower to the ground.
The other "L" under the left side of the seat (as you sit) is the fall or flow rate....which regulates the speed the implement will drop.
Most tap into the high pressure hydraulic line and return line to produce a hydraulic circuit for hydraulics.
Regards, Mark
Thanks Mark. /forums/images/graemlins/grin.gif
   / YM1700..Hydraulic valve #4
2020 Sellick S80 (A50123)
2020 Sellick S80...
2020 CATERPILLAR 259D3 SKID STEER (A51246)
2020 CATERPILLAR...
2025 CFG Industrial QH12R (A50123)
2025 CFG...
2025 Forklift Safety Basket Attachment (A51691)
2025 Forklift...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
