YM1700 High/Low shifter broke
   / YM1700 High/Low shifter broke #1
rockb
Yanmar 1700
The hook on the High/Low shifter broke off. I removed the handle to be able to tap the old one out by pushing it into the case. Not a problem removing the old one as I tapped it from the inside out but cannot figure out how I am going to get the new one in as it will have to be put in from the inside.
Attached is a pic of the old one. As you can see it still needs to go at least another 1/4". Is there a trick to this or do all those gears need to come out?
   / YM1700 High/Low shifter broke #2
An enlarged view . . .
So I was able to beat the broken one out from the inside but the new one would not go in that way and was hitting the same shaft so I notched it out with a bandsaw and was able to get it in from the inside. Works to go from High to Low but now when I put everything back together tractor will not go into Neutral using main shifter.
   / YM1700 High/Low shifter broke #4
:oops:
Lets back up.
1. The original shift from HI-LOW broke.
2. You replaced the HI-LOW shifter.
3. No Neutral.
In event 1, is it possible the HI-LOW shifter broke due to some unknown binding inside. And now with the replacement, the tractor can not go into neutral?
You didn't mess with anything else from what I can see. The underlying problem still is there. :unsure:
   / YM1700 High/Low shifter broke #5
It's possible that when putting the top cover back on, the forks for the main shifter didn't go in the right places. You may want to check that out.
   / YM1700 High/Low shifter broke #6
It probably is installed before the shaft/gears are in place.
This is what I am suspecting but how do I know the "right places"?
   / YM1700 High/Low shifter broke #8
You really have to watch it as you put the top cover on. Make sure the gears and forks are aligned so you can drop the top cover.
   / YM1700 High/Low shifter broke #9
Don't know your location? Same as the YM1700. Listed YM2000 Cheap Replacement. Should be complete. Facebook market 50.00$ Florence MS. the shifter looks to be there all intact!
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2019 F150 (A56435)
2019 F150 (A56435)
25ft Tag Trailer (A56435)
25ft Tag Trailer...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
