YM1610D will not move fwd or bwd any gear or range.
   / YM1610D will not move fwd or bwd any gear or range. #1
Henhouse1
YanMar YM1610D
PTO, 3 pt, most of FEL works. FEL is jerky. 3 pt waits several seconds longer than normal before operating at normal speed. Are these symptoms common for a clogged filter?
   / YM1610D will not move fwd or bwd any gear or range. #2
Yup! With no visible problems. And clean the pickup or a Valve body screen and filter replaced or whatever it calls for. I believe that is the problem...
Thanks!
Pulled filter this morning. Yuuuuuccccchhhh!!! Wish I had taken a picture. Cleaned filter and filled with 3.5 gal of 303. NEW TRACTOR!!!! Everything smooth and fast!
However, loader still droops, but not nearly as fast. It appears the right cylinder is bypassing because pump doesn't drag down till the left cylinder extends a tiny bit after the right one stops moving. Anyone know where to take a hydraulic cylinder for rebuilding? Would an automotive machine shop be able to do it?
Thanks guys! Saved my Azz again!
Stan Henley
   / YM1610D will not move fwd or bwd any gear or range. #5
There are specialty hydraulic shops anywhere there are tractors, construction equipment, trucks, forklifts, etc. Possibly the nearest big city but in my case adjacent to a farm town of 10,000.
I paid $165 to have a cylinder resealed. I watched, it looked simple. So next time I went to HF and bought a 36" pipe wrench, added a cheater pipe on that, and disassembled the cylinder myself. $10 for seals total cost.
Pro tip: leave the cylinder attached while you loosen the end cap so you have something to pull against. And leave the opposite end attached when you unscrew the bolt at the tip of the internal piston rod.
This isn't complicated. Just be careful to not ding any precision surfaces.
Thanks! I am a recently retired Delta aircraft mechanic so I should be able to beat any precision surface into submission with the only tool I use since, my trusty BFH! ;0)
Don't know her. I was in Atlanta Tech Ops in the APU shop for the past 25 years.
   / YM1610D will not move fwd or bwd any gear or range. #9
My cousin and her husband both work for delta @ Hartsfield. For as long as I can recall. He's a Tech and she's a over sea's attendant...... Good for you to be on here!! BTW..........
   / YM1610D will not move fwd or bwd any gear or range. #10
I just looked at Wikipedia, Delta has 86,000 employees! I can see how you don't all know one another.
I have a relative in Delta too, a station agent for years then he transferred to purser/flight attendant working out of Atlanta for the final years of his career. He and his wife travel at every opportunity. They've been everywhere. Weekend in London, Paris, Rome, wherever, no problem!
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
New Hitachi 10.5' Wheel Loader Bucket (A50774)
New Hitachi 10.5'...
2013 Hyundai Azera Sedan (A50324)
2013 Hyundai Azera...
EZ-GO Freedom RXV Electric Golf Cart (A50121)
EZ-GO Freedom RXV...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
