YM1601D Front Wheel Drive Question
   / YM1601D Front Wheel Drive Question #1
frankmako
North Georgia
Ford 4610, Ford 3910 and YM1601D
On the 1601D model, what is the postion for the shift lever when the tractor is in 2-wheel drive? Is the lever back (toward the rear of the tractor) for two wheel drive and forward for four wheel drive?
I took look at a Yanmar operation manual for the YM1401/YM165D and the book states; pull the lever back to engage the front wheel drive and push the lever foward to disengage.
So which way does the YM1601D lever goes for two wheel drive???
   / YM1601D Front Wheel Drive Question #2
On my 1610d back is 2wd,foward is 4wd.Not sure about yours but could'nt you do a test ?I mean put the leaver back and then back it up a slight incline to where one of the rear wheels starts to spin and then put the lever foward and see if you get "unstuck".I just checked the manual for a 1510d and it also says back 2wd foward 4wd.hope this helps.
   / YM1601D Front Wheel Drive Question #3
Forward for both models 1601D and 1610D.
I don't recall any Yanmar model that doesn't operate in four wheel drive with the selector any other way than forward.
That's what I thought. But,,,,,in the manual for the YM1301/1401 it states,, Front wheel drive (YM165D). Pull the lever back to engage front wheel drive and push forward to disengage. Even the pictures show this. So after I reading this I had to asked the question. Which way????
I know that this manual is not close to my tractor, but some of the information in it cross over. And it has pictures!!
This weekend I will do the backing up a steep hill deal... I got a good one one the farm. It works the Ford 3910 hard while backing up the hill, so it should tell on the front wheel drive.
I hope someone out there has a 1601D and they can set me stright.
Thanks
Frank
   / YM1601D Front Wheel Drive Question #5
my 3110D is foward for 4 wd
   / YM1601D Front Wheel Drive Question #6
Thanks
Frank
I have a YM1601D and a YM1610D (and a 1300D and 1401D).
   / YM1601D Front Wheel Drive Question #7
The YM1601, YM1610, YM1401, and most other models are, as Mark said, 4wd=forward. Some models though like the YM1500 & YM165 are 4wd=back which seem a little counter-intuitive to me.
Aaron
Parts@HoyeTractor.com
(940)592-0181
1999 WABASH 48X102 FLATBED TRAILER (A53843)
1999 WABASH 48X102...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A53843)
GRID SHAPED BUCKET...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
