YM1601D Front Wheel Drive Question
   / YM1601D Front Wheel Drive Question #1
frankmako
Bronze Member
North Georgia
Ford 4610, Ford 3910 and YM1601D
On the 1601D model, what is the postion for the shift lever when the tractor is in 2-wheel drive? Is the lever back (toward the rear of the tractor) for two wheel drive and forward for four wheel drive?
I took look at a Yanmar operation manual for the YM1401/YM165D and the book states; pull the lever back to engage the front wheel drive and push the lever foward to disengage.
So which way does the YM1601D lever goes for two wheel drive???
   / YM1601D Front Wheel Drive Question #2
On my 1610d back is 2wd,foward is 4wd.Not sure about yours but could'nt you do a test ?I mean put the leaver back and then back it up a slight incline to where one of the rear wheels starts to spin and then put the lever foward and see if you get "unstuck".I just checked the manual for a 1510d and it also says back 2wd foward 4wd.hope this helps.
   / YM1601D Front Wheel Drive Question #3
Forward for both models 1601D and 1610D.
I don't recall any Yanmar model that doesn't operate in four wheel drive with the selector any other way than forward.
That's what I thought. But,,,,,in the manual for the YM1301/1401 it states,, Front wheel drive (YM165D). Pull the lever back to engage front wheel drive and push forward to disengage. Even the pictures show this. So after I reading this I had to asked the question. Which way????
I know that this manual is not close to my tractor, but some of the information in it cross over. And it has pictures!!
This weekend I will do the backing up a steep hill deal... I got a good one one the farm. It works the Ford 3910 hard while backing up the hill, so it should tell on the front wheel drive.
I hope someone out there has a 1601D and they can set me stright.
Frank
   / YM1601D Front Wheel Drive Question #5
my 3110D is foward for 4 wd
   / YM1601D Front Wheel Drive Question #6
Frank
I have a YM1601D and a YM1610D (and a 1300D and 1401D).
   / YM1601D Front Wheel Drive Question #7
The YM1601, YM1610, YM1401, and most other models are, as Mark said, 4wd=forward. Some models though like the YM1500 & YM165 are 4wd=back which seem a little counter-intuitive to me.
Aaron
Parts@HoyeTractor.com
(940)592-0181
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
44029 (A51692)
44029 (A51692)
GENERATOR (A53843)
GENERATOR (A53843)
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
