Tires YM1510D Custom Turf Tires
   / YM1510D Custom Turf Tires #1
htiek126
Southern Maryland
Iseki TA270F, Yanmar YM1510D, Mitsubishi MT2201D
I thought some folks might be interested in my inexpensive turf tires. I installed 4.80-12 trailer tires ($18 each) on the front wheels, and 285/75R16 truck tires ($25 used pair) on modified rear wheels (drilled new bolt pattern). All the diameters are the same as the original tires, and I still have the rear rice tires for snowy days. Pictures attached.
Rear View...
Front view...
   / YM1510D Custom Turf Tires #4
Fantastic! My kind of a solution (cheap).
Why did you need to drill the rear wheels? They look the same as ours. Did I mis-understand?
cvt
   / YM1510D Custom Turf Tires #5
Nice job! How are the tire and wheel sizes in relation to the 4WD? Or do you not use it with that turf setup?
Mark
The John Deere bolt circle on the wheels was too large, so I had to drill a smaller diameter circle for the lug bolts.
The tire diameters are same as the original rice paddy tires. I drove in 4WD on pavement, and there does not seem to be any wind up in the drivetrain. I also laid down some rubber accidently. I shifted the powershift a little too quick, and the rear wheels actually chirped before they grabbed on the cement. I might need to bolt the seat down a little tighter with all that traction. /forums/images/graemlins/grin.gif
   / YM1510D Custom Turf Tires #8
Nice looking set up. Thanks for the tire size info. I have the same model tractor and am in need of new tires. I have found new agricultural tread fronts mounted for $70 each, but this seems a bit high for such a small tire. I have found the rears for $120 each mounted and that seems more reasonable.
   / YM1510D Custom Turf Tires #9
Keith
very nice set up you have there, do you mow your lawn with it ? I know that Leonard Sheaffer use to sell mid mount mowers that ran off the rear pto. I have a set of diamond tread turf tires mounted on rims for a YM1401 but I dont own a 1401. so they just collect dust. I drove a mahindra 2015 with turf tires the other day and man was that a smooth ride
on blacktop or gravel. again nice rig you have there.
Ernies imports
   / YM1510D Custom Turf Tires #10
Then what you've got is a set John Deere rims (on the rear) with 285/75R16 tires on them(?).
Still a great solution!
cvt
2021 John Deere C12R Corn Head (A53342)
2021 John Deere...
Kubota Salt-Spreader (A52384)
Kubota...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
