YM1500D Version
   / YM1500D Version #1
Anonymous Poster
Epic Contributor
I have recently purchased a YM1500D. I have seen several threads that referenced older and newer versions of the 1500D. Can someone describe how to differentiate between the two versions?
   / YM1500D Version #2
Older models won't have a fuel pedal newer ones will.
   / YM1500D Version
So, if I understand this correctly; it is an older version if the engine speed is controlled by a hand lever on the right side of the instrument panel rather than a foot pedal.
   / YM1500D Version #4
Not entirely true about the foot throttle. I have seen late models with and without the foot throttle. The older models had green wheels, hoods, and fenders with a black frame/engine. The later models had the red hood and fenders, off white wheels and a green frame/engine. Of course a lot of people repaint before they sell them so how can you tell the difference then? Here is how! The sure way to tell is whether the bell housing is cast or stamped steel. If the bell housing of the transmission has a smooth finish it is an older model. If the finish is a rough cast iron finish, it is the later and heavier model.
   / YM1500D Version #5
true, some people have adapted the foot throttle to the older models
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
