YM1500 Wiring diagram
   / YM1500 Wiring diagram #1
del10820
Central OK
Yanmar YM1500, Yanmar FX26D/Koyker FEL
Looking for a wiring diagram for my YM1500 .
When my son whent to start the tractor the battery was down and would not turn the engine over fast enough to start When he released the compression lever (engine stoped turning). He hooked up the jumper cables to jump start it and the "smoke god" escape under the dash at the voltage regulator wire,and burnt the insulation off . Probabley hooked up backwards (not me syndrome), but he said no , probabley been done more than once in its life. Also has not been keeping battery charged the last couple of times we used it ,we had cleaned the cables at the battery a few weeks ago when it did not start. Need to trace down the wire to see where it goes and what it hooks up to.
Has any one changed out the alternator to a high amp one?
Del
Thank you Winston1, it will give me a starting place. I knew they were simple but did not relize that simple.
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
