YM1500 Red or Green
   / YM1500 Red or Green #1
jeffscoggins
Brainerd, MN
Melroe 610
I just bought a YM1500D, which is red. But I'm beginning to suspect someone painted it red and it's really a green because parts aren't matching up. For instance, the rear axle cover is much more like the green model than the red. My problem is that the seals I ordered don't fit my rear axle, and I haven't been able to find the right ones since I'm not really sure what I'm looking for. Is it possible someone could have matched up a rear end from an entirely different tractor?
Thanks,
Jeff
   / YM1500 Red or Green #2
I know from talking to a new and used parts supplier, that the 195 g 240 g and the 1500 r and the 2000 r have the same rear and transmission. To the best of my knowledge they are all painted black. and use the same parts. Call this number and ask for Len 815-284-3226.
   / YM1500 Red or Green #3
The older YM1500 have a rearend like a YM155. The older YM1500 (green/black) has a steel clutch housing & no axle housing with a long axle shaft. The newer YM1500 (red/grey) has a cast clutch housing with axle housings & a seal/bearing retainer on the end of the housing.
That sounds right! I've been trying to find the seal/bearing retainer at the end of the housing, but haven't been able to. I actually don't need the retainer, just the seal, but I can't even find anyone who knows what I'm talking about. I've ordered three different seals but none of them are quite right. Any idea where I can find a diagram of this particular housing? Hoye gets close, but not quite.
Also my tractor also has a welded hub on the axle, rather than a removable hub. Until you answered this post I had about decided I had some kind of a rig job for a rear end.
   / YM1500 Red or Green #5
Email me the OD of the shaft & the ID of the housing & I'll supply you with a seal.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
MISSION 4X3X14 CENTRIFUGAL PUMP (A53843)
MISSION 4X3X14...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2022 ALLIANCE NORTH AMERICA, INC SDG45 GENERATOR (A53843)
2022 ALLIANCE...
