YM135 Bolt Thread Sizes, Better Assembly Images/Instructions
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #1
scottw99
Ontario, Canada
Yanmar 135
So I have a ym135 in my garage that I picked up. It's split with the back half assembled but the front half (bell-housing forward) is completely in pieces. From all of the manuals I've read and seen so far I can't find any good images or diagrams of the entire engine/rad/mounts/front end going back together - is there anything better?
Also it's missing a lot of fasteners. In the parts manual it lists bolts as "MX x X" or M8 x 12 for example, but that doesn't follow any bolt nomenclature I've seen before. Is that diameter x length? What about thread pitch?
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #2
Sending you a pm. Yes, M8 x 12 is bolt size by length. Most frame bolts will be the course thread for what that is worth.
Maybe 1mm pitch for the coarse ones? m8x1x12?
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #4
I don't want to mess you up, you may need to procure a thread gauge. 1.25 is course, 1 is fine. I can't warranty either, sorry.
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #5
And there is even a M8 1.5 to make things even more confusing :) I dont know if Yanmar uses any of them but I noticed my tap set had a M8 1.5 tap.
I measured one of the transmission plate cover bolts earlier and it was 1.5
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #7
Sounds like you have it figured out but yes m8x12 is a bolt size. It's diameter and length
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #8
They'll be 1mm fine and 1.5 course. Toyota use 1.25 and I'm not aware of many others using it.
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
