YM135 Bolt Thread Sizes, Better Assembly Images/Instructions
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #1
scottw99
Ontario, Canada
Yanmar 135
So I have a ym135 in my garage that I picked up. It's split with the back half assembled but the front half (bell-housing forward) is completely in pieces. From all of the manuals I've read and seen so far I can't find any good images or diagrams of the entire engine/rad/mounts/front end going back together - is there anything better?
Also it's missing a lot of fasteners. In the parts manual it lists bolts as "MX x X" or M8 x 12 for example, but that doesn't follow any bolt nomenclature I've seen before. Is that diameter x length? What about thread pitch?
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #2
Sending you a pm. Yes, M8 x 12 is bolt size by length. Most frame bolts will be the course thread for what that is worth.
Maybe 1mm pitch for the coarse ones? m8x1x12?
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #4
I don't want to mess you up, you may need to procure a thread gauge. 1.25 is course, 1 is fine. I can't warranty either, sorry.
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #5
And there is even a M8 1.5 to make things even more confusing :) I dont know if Yanmar uses any of them but I noticed my tap set had a M8 1.5 tap.
I measured one of the transmission plate cover bolts earlier and it was 1.5
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #7
Sounds like you have it figured out but yes m8x12 is a bolt size. It's diameter and length
   / YM135 Bolt Thread Sizes, Better Assembly Images/Instructions #8
They'll be 1mm fine and 1.5 course. Toyota use 1.25 and I'm not aware of many others using it.
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A51572)
1989 Chevrolet...
TEST BID LOT (A50775)
2004 Mercedes Benz E-Class Sedan (A50324)
2004 Mercedes Benz...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
