YM1300 upper lift arm
   / YM1300 upper lift arm #1
DarinM
Texas
Yanmar YM1300
I have a YM1300. The upper lift arm on the left (clutch) side just broke off! Broke in half. Didn't have any load on it either. I just ordered a set of lower arms from Ernie's to help with the width issues. But my question is this. On the YM1300, it seems that the upper lift arms were mainly designed to lift the tiller and it had a 3 point conversion put on to use other Cat1 items. Since I am using it to lift a 48" king kutter brush hog and box blade, am I overloading the factory arms? Will I continue to have issues such as this? At $85 ea this will get to be an expensive fix each time it breaks. My initial thoughts were to have a machine shop fabricate new ones from plate steel?
I'd love to get your input or comments on this or similar experience.
Thanks in advance!
   / YM1300 upper lift arm #2
This is not a common problem. I sell very few upper lift arms. Never sold one for a YM1300.
   / YM1300 upper lift arm #3
If the three-point conversion isn't just right, it could be binding up. Check the upside down "U" shaped pieces that fit over the lower arms to make sure they do not bind at the lower arms when lifted all the way up, also check to make sure the check-chains don't bind when lifted up high.
I've only seen them break in situations like that.
Ernie's sets are built right and won't bind.
Thanks Dave, The new arms should be here tomorrow and installed this weekend. The replacement upper arm is being installed by the dealer I purchased it from and will be completed tomorrow. I won't even bother with hooking up the factory units. Hopefully this will be the end of this issue ! I only wish I wouldn't have already trimmed the PTO shaft for the bush hog. The new arms will most likely mean a longer PTO shaft. Oh well, live and learn.
Thanks for your input!
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2012 L3 MEP-806B GENERATOR (A52576)
2012 L3 MEP-806B...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
