YM1100D and YM1110D engine parts
   / YM1100D and YM1110D engine parts #1
snbgreen
Hood River
Yanmar 1110D
I own a YM1110D I looking into rebuilding the engine. It's my understanding that the 1110D engine = 2T72 and the 1100D engine model is the 2T73... do they share the same engine parts... for an engine rebuild?
Thanks in advance.
Jeff
   / YM1100D and YM1110D engine parts #2
Don't know where the 2t73 came from. Never heard of it. I believe they have the same 2t72
engine.
Woops, wrong again. I see the 135 has the 2t73 engine, however, both the 1100 and 1110 have the 2t72 engine.
I give up, further research in part manuals does show the 1100 does have the 2t73. Moral of the story is don't believe anything I've said.
I dug up the PDF manual and the manual list the engine model as
1100 = 2T73
1110 = 2T72
part numbers are similar numbers are ...(last 5 digits)
- 1100 Valve exhaust
- 1110 Valve exhaust
   / YM1100D and YM1110D engine parts #5
1100 = 2T73
1110 = 2T72
View attachment 848059 - 1100 Valve exhaust
View attachment 848060- 1110 Valve exhaust
We have the Parts Manuals on the YTOG for free as,
YANMAR YM1100 1ST EDITION PARTS MANUAL NPC-9012.pdf - - - > 2T73
YANMAR YM1100 PARTS MANUAL NPC-1038.pdf - - - > 2T73
YANMAR YM1101 PARTS MANUAL NPC-1044.pdf - - - > 2T72
YANMAR YM1110 PARTS MANUAL NPC-1040.pdf - - - > 2T72
Hope I don't confuse people here. :LOL:
Nearly all 1st edition machines are Tree Frogs and the later editions are Red Apples.
   / YM1100D and YM1110D engine parts #6
I'm see a WS-73 Wet sleeve 135, 1100 (2T37A)
I'm not showing anything (2T72) I'm going to see what shows up when I search it.
I can't find any info on YM 1110D parts for an engine rebuild. From online info the 1100 and 1110 tractor are 11 HP...
   / YM1100D and YM1110D engine parts #8
I'm going to look at the YM135 and see how close it is. Nothing on the Net. either for my search 2T72. The Wet Sleeve showed up on my old Fredricks parts.
   / YM1100D and YM1110D engine parts #9
I can't find any info on YM1110D parts for an engine rebuild. From online info the YM1100 and YM1110 tractor are 11 HP...
Do use the YM in front of the model IDs, else people will point you to Kubota parts. :LOL:
The 2T72 was also used in early Yanmar gensets. These gensets were sold in English speaking countries. The engine would be 90% identical to your tractor. The only difference is the engine back end is not to a tractor clutch.
From the YTOG, look for this English written engine manual. (y)
YANMAR ENGINE 2T72HLE-S- PARTS MANUAL 0CI00-M24600EN.pdf
   / YM1100D and YM1110D engine parts #10
The 2T72 uses these parts,
YM1110 2T72, Y-124901-22090 Piston Kit, 72mm P20 C30mm
(same piston in the YM1401, Piston 72mm TW 46 1401 F15 (flat)
Buy the ring-set for the YM1401. You will have one extra set.
The rings fit these models too, YM1110, YM1401, YM1510, YM1502, F15
Even download these manuals from the YTOG to verify the part numbers. (y)
YM1110 2T72, Y-2T72-15, Engine Block Liner/Sleeve 72mm (Finished/Polished) TW
(same liner as the 3T72 engine, ΥM1401, Y-3Τ72-15)
* NOTE, the 2T73 engine liners are DIFFERENT.
Notice the TW at the end of this Yanmar listing. The OE for the liners Yanmar has used for the past 60 years is,
YM1110 2T72, Y-2T72-2, Head Gasket, 2T72 (2GM20F Marine engine variant)
OR ...
YM1110 2T72, Y-2T72-4, Full gasket engine kit complete
To play it safe, it would be wise to download the Parts Manuals for the models with the 3T72 engines. Compare the 2T72 part numbers with those part numbers in the other manuals. Then sleuth out the details of where to get the parts.
Weavers has a large PDF downloadable Yanmar parts catalog for the Gray Market machines.
The Yanmar genset with the 2T72 engine is the AG8S model if you go searching for engine kits that way too.
Just giving you options.
Wood Fence Posts (A50121)
Wood Fence Posts...
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
Case 588G (A50120)
Case 588G (A50120)
2023 Icon I40L Electric Cart (A50324)
2023 Icon I40L...
2025 12v Diesel Pump, Hose And Nozzle (A50323)
2025 12v Diesel...
