YM 2700 single indicator light
   / YM 2700 single indicator light #1
Johnc65
Unlike some other Yanmars that have several indicator lights, my YM 2700 only has one indicator light (red) which is located just to the right of the tachometer, and I have no idea what it indicates. Is it temp., charging, oil pressure, or what? Does anyone know?
   / YM 2700 single indicator light #2
What gauges do you have? Might do process of elimination.
   / YM 2700 single indicator light #3
Make sure the light is working. If it's the Water/Temp remove and ground out the wire to sender and should come on. If it's the oil pressure it should come on until the oil pressure comes up on a cold start.Those are the easy ones. Or you may just have to trace the wires.
Carey
   / YM 2700 single indicator light #5
Low electrolytic battery light?
Thanks for the responses. Sorry I've been away from the computer for a few days. Winston - Besides the tachometer, the only gauge on the dash is the temp guage. Neat 1500 - The light has two wires. One goes to a wire junction just behind the dash. The other wire joins several others through a conduit going toward the front of the tractor. The wire going from the light is yellow, and the only yellow wire coming out of the conduit is going to the top and front of the engine into what I believe looks like the water pump, but not positive at this point. Would the tractor have a temperature gauge and a temperature light?
Paul (Neat 1500) -- I just had message from another site where I was also told that the indicator light was for oil pressure. If it wasn't for the temp guage already being there, I would have sworn the light was for water temp. Thanks again for the info.
   / YM 2700 single indicator light #9
Makes sense, never seen a tractor without an oil gauge or oil light. All have one or the other.
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
378807 (A51572)
378807 (A51572)
