YM 240 D Hydraulic Question
   / YM 240 D Hydraulic Question #1
Rogerrl
I have a YM240D with Yanmar loader and Yanmar Backhoe. The back hoe is ran off PTO pump. The problem I have is the loader is way slower than I like. It runs off tap in block on tractor hydraulics. What i need to know is the tractor loader system an open or closed system? What i want to do is operate the loader with the PTO pump for higher flows. Thinking I could quick connect the lines in some how depending on what type of system. I would just do it with the PTO pump but I do sometimes take back hoe off. I would appreciate any thoughts.
   / YM 240 D Hydraulic Question #2
Open center. You can run it off of the pto pump.
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
INGERSOLL RAND...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2015 Volkswagen Passat Sedan (A51694)
2015 Volkswagen...
2022 VERMEER RTX250 WALK BEHIND TRENCHER (A53843)
2022 VERMEER...
