YM 2210D How does it work?
/ YM 2210D How does it work?
I dont know where the ice was located. The back wheels would not roll until the tractor had thawed. Thanks, Tom
/ YM 2210D How does it work? #22
Just writing out my thoughts on this. Am I understanding correctly that the engine is taking on a load when you let the clutch out? As your manual probably states one of your possibilities is low main relief valve pressure. I think this might be an easy check for you. Those plugs you spoke earlier about are for checking your operating pressure and your lubricating pressure. I cannot tell you which is which but your manual should. I can only tell you the 226 operating pressure should be between 213psi and 227psi. This is with the transmission warm and in any gear. The lubricating pressure should be between 5.4psi and 6psi on the 226. Only reason I state this is you can immediately tell which port you have put the gage on. If those ports are easy access and you have a gage this might be something worth checking. Just a thought. Your repair manual should have the numbers pertinent to your 2210.
Winston. I am following #1 in the attached document. It might be useful for others as well. Tom
  • Power Shift Transmission Trouble shooting.PDF
/ YM 2210D How does it work? #25
The water/ice will be at the bottom of the gear boxes since oil is lighter than water and will lock up/break the gears when frozen.
Usually just cracking the plug the water will come out first if its sat awhile and the plug is dead low point.
I just wanted to let everybody that have helped me with my tractor know that today I finally got it moving. I got it moving by engaging the diffential lock pedal. Because of time restraints, I dont know why yet, but that is what happened. Today I drow the tractro 30ft out of the garage, all gears worked and all power shift positions worked, forward and reverse. Now I have to figure out what is going on and why?
Found this link with a similar problem.
http://www.yanmarowners.com/phpbb/viewtopic.php?f=1&t=1494&p=6833&hilit=diff+lock#p6833
Again THANKS FOR ALL YOUR HELP.
Tom
/ YM 2210D How does it work? #27
I just wanted to let everybody that have helped me with my tractor know that today I finally got it moving. I got it moving by engaging the diffential lock pedal. Because of time restraints, I dont know why yet, but that is what happened. Today I drow the tractro 30ft out of the garage, all gears worked and all power shift positions worked, forward and reverse. Now I have to figure out what is going on and why? Again THANKS FOR ALL YOUR HELP.
Tom
You have an axle that is not engaging the side gears in the diff either its broken or has stripped the splines.
I cant tell you why but the is the only logical explanation for locking the diff and it goes. hth
/ YM 2210D How does it work? #28
This time drive your tractor and step on the field brakes. Make sure you can operate them independently. Whichever one labors/stalls the engine is the driving wheel. You'll probably have to tear the rear end apart to diagnose it, but you could at least isolate the problem to left or right side.
To those who have a manual, how are the axle shafts retained on these? Do they have C-clips, or are they tapered bearings, or something else?
/ YM 2210D How does it work? #29
Quote from Mark_VA in March of 2002
I replaced the rear axle seals on my 2210 last spring. I not only had to remove the hydraulic lift assembly, but it was necessary to remove the PTO transmission in order to access the interior axle retaining bolts. It was a great educational opportunity to see and appreciate what makes everything move! One of the biggest challenges was to reinstall the two PTO shift linkage pins without dropping them to bottom of the rear end (long surgical forceps were invaluable for this).
Would anyone of you great board members, be able to give me input as how to SAFELY jack up my tractor, if I were to pull the right axle housing off??? Do you need a floor jack or a bottle jack??? What tonage should the jack be rated at??? Stands??? I am inexperienced, but mechanically inclined, and I don't want to get into a situation with the tractor tipping when attempting to pull off the axle cover.. Thank you very much! Tom
/ YM 2210D How does it work? #31
The one time I had to do something like that I was able to back out some bolts that acted as stops on the articulating front axle. This effectively kept the machine from rocking on the front axle pivot. Then, a jack and some jackstands under the center of the transmission case and opposite side axle housing holds things stable and secure.
Here is an update of the status of my YM 2210D that would not go forward. With the help of my Buddy that is visiting from overseas, we finally took the time to take the tractor a part to located the problem. The problem is in the Transmission housing (inner). We found that the (final reduction pinion) had snapped in two. It is parts #61 on the attached drawing. The drawing is from a ym240, it is supposed to be very, and looks to be very similar to my 2210d.
We put a call into Hoye and they are searching for a part for us, so far no luck,... but I am sure they will find us a pinion. Thanks Tom.
  • ym 240 transmission housing.pdf
Attached is the correct parts page for the 2210D. It is #21 that had snapped. I got a new one from Hoye. I will put it in when time permits. Have a good day. Tom
  • YM2210 58.pdf
/ YM 2210D How does it work? #34
Just curious what it cost you? And how many hours do you have into the tear down?
I got the part from Hoye. They had a used part. My buddy tore down the tractor and found the broken part in 2 hrs. As you can see from the start of this posting, I originally knew nothing about this tractor, (and I MEAN NOTHING!!!) I was even uneasy about how to jack up the tractor. Once my buddy showed me, It would have taken me 8 hrs or more to find the broken part. I spent another 8 putting it back together by myself. The hardest being not to drop the locking pins for the PTO gear shifters inside the PTO housing and making one of my own gaskets. ( and to find the time) Finding the correct parts diagram also helped. Had my buddy been here, he would have done the same job in 3 hrs, but he is a PRO. The tractor now runs just like it should on the back end,... I am very pleased.
Time to take a look at the front end,.. that will be another learning experience,... and another posting :laughing:,.... Tom
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
INTERNATIONAL 454 TRACTOR (A62130)
INTERNATIONAL 454...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
KJ K2545W 46'x25' Metal Garage (A60463)
KJ K2545W 46'x25'...
2019 Ford F-450XL (A60462)
2019 Ford F-450XL...
Big 12 PT Module Builder (A60462)
Big 12 PT Module...
