ym 2000 wet brakes
   / ym 2000 wet brakes #1
ray_reilly
Central Florida
YM 2000
I saw this in an old post any one else besides me have one? My Right brake sticking, after parked I have to lock Diff to get it free once broke loose it will roll till parked again put right pedal is frozen. Was told to adjust assuming I had dry brakes found no adjuster. I checked and appears hydro/tran fluid low. Will topping off free brake pedal? Any suggestions? Below is thread on wet brakes.
http://www.tractorbynet.com/forums/yanmar/100111-ym2000-brakes.html
Thanks
   / ym 2000 wet brakes #2
Ray no adding hydro fluid on a 2000 won't help the brake.Your adjustment is the brake shaft/rod.Loosen the locking nuts and the middle adjuster will move.In hence making the shaft longer or shorter do both sides/pedals equally.If the pedal is sticking first I would grease the pedal shaft and then as California stated earlier the shaft going into the housing plate may be dirty or you might have to remove it to have looksee inside.
   / ym 2000 wet brakes #3
If they have never been apart. Take them apart. Probably all rusty / gunk inside the drum.. I think that's the case on most... I don't think you have wet brakes on that mod.
   / ym 2000 wet brakes #4
Ray if you do pull the cover please respond and let us know if it is full of oil pics of the internal parts would be nice if so.
   / ym 2000 wet brakes #5
New conversion kit.
It's raining just couldn't help it.
won't be able to get to til Saturday but will take photos of what I find ?
Thanks will post back sat evening
Ray
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
Payment Terms (MUST READ) (A50775)
Payment Terms...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
Zero Turn Mower (A48082)
Zero Turn Mower...
