ym 2000 rear axle tube removal
   / ym 2000 rear axle tube removal #1
mah1
I have a leak where the axle tube meets the diff. Will the axle tube come off by removing the outer bolts or is there something inside that has to be removed?
   / ym 2000 rear axle tube removal #2
I think you may be able to just pull just the housing but we always remove the axle shaft first. Just remove the PTO assembly, remove the (super tight) bolt that holds the bull gear to the axle shaft & pull out the axle. It is just a lot easier (in our opinion) to do it that way.
Aaron
Parts@HoyeTractor.com
(940)592-0181
Thanks Aaron, The axle seal is leaking also and will be replaced. After the hub, axle seal, collar and housing bolts are removed, will the housing slide off of the axle without removing the PTO?
   / ym 2000 rear axle tube removal #4
I think you may be able to but I'm not sure. We never do it that way. The PTO is very easy to remove. It just comes out as a complete assembly all bolted together.
Aaron
(940)592-0181
Thanks Aaron, I was trying to help a guy with this but I couldn't get the hub off and didn't want to be responsible for breaking something. So, I sent him to a full time-tractor mechanic. I gave him your contact info for parts.
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
2018 FORD F-150 (A53843)
2018 FORD F-150...
(3) FLOOR JACKS (A53843)
(3) FLOOR JACKS...
378811 (A51573)
378811 (A51573)
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
