YM 2000-problem of push from implements?
   / YM 2000-problem of push from implements? #11
Re: YM-2000 PTO problem
Three speed PTO shifting problem. PTO engaged in position N - 2 - 3. Position 1 seems to want to load engine with no PTO drive. There is no neutral position found. Anyone know what is happening here short of opening the transmission case?
Any progress?? :confused3:
   / YM 2000-problem of push from implements? #12
Thanks for the reply. It appears that the real magic was adding about 2 gallons of fluid to the transmission to bring it up to the correct level. After that the PTO starting working correctly. I would guess that a gear was sticking on the shaft and the fluid loosened it up. This tractor had been sitting up for several years and just recently brought back to life.
   / YM 2000-problem of push from implements? #13
wow so there was only like half full!! hopefully its not to much of a rusty mess in thier!
   / YM 2000-problem of push from implements? #14
Checking fluid is not considered "opening transmission case":).
   / YM 2000-problem of push from implements? #15
2 gallons short of fluid on a tractor that sat unused for several years?
I wonder if most of what remained in there was simply water. After it has run for a while, I would dip a stick in there and see if it comes up with pure fluid, or water/fluid whipped to white foam.
   / YM 2000-problem of push from implements? #16
I just revived a YM2000. First thing I did when I got it home was remove the drain plug from the bottom of the transmission and about a half gallon of water came out. I would do that first.
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2018 Wacker Neuson WL 38 (A52128)
2018 Wacker Neuson...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
