YM 195D
/ YM 195D #1
hamiltor16
Southwestern Ontario
YM195D and Zetor 8045 Case 580SK kubota 2320 fel
I just purchased one and wanted to find out
about if a backhoe and bucket are available
It is a 1990 came with a roller rototill front blade
snowblower
/ YM 195D #2
I believe the YM195D's were made in 1979 and 1980, so you might be off a decade on the year model. Koyker makes a lot of loaders for Yanmars, although they do not list one for the 195, I suspect they have one that would fit. Perhaps someone that is more knowledgable on the 2-cylinder Yanmars could figure out which mount kit would fit. They have 3-point backhoes as well, but an operator must be careful on three-point hoes not to get carried away or you could damage the tractor. Subframe mounts are best, but are not available for all models.
/ YM 195D #3
the 195 and 240's are close in size to the 1700, if anyone knows which mounts those take, it would at least be a start.
Soundguy
/ YM 195D #4
The YM1700, 1900 and 2000 all take a 110 Koyker loader and mount kit K665769, hose kit K665254. This should work on the 195 with little or no modification. Thanks Soundguy for the info on size. Dave
/ YM 195D #5
The Kelly DL1000 loader will fit on the YM195 nicely. It would require drilling 4 holes in the lower mounting bracket. 4' or 5' bucket available which is sized for the size of the tractor. I feel the Koyker uses to large of a bucket for the smaller tractors. The Kelley B650 backhoe would also be a good match for the YM195. contact me for pricing with a 20% discount. 1980 is closer to the true year.
2003 HRTO 14ft. Enclosed S/A Trailer (A61574)
2003 HRTO 14ft...
case 370 glass door never installed (A61307)
case 370 glass...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
2019 Dodge Grand Caravan Van (A61574)
2019 Dodge Grand...
2025 JMR Tree Boom Skid Steer Attachment (A61572)
2025 JMR Tree Boom...
Case IH 5100 (A64119)
