YM 195D
   / YM 195D #1
hamiltor16
Southwestern Ontario
YM195D and Zetor 8045 Case 580SK kubota 2320 fel
I just purchased one and wanted to find out
about if a backhoe and bucket are available
It is a 1990 came with a roller rototill front blade
snowblower
   / YM 195D #2
I believe the YM195D's were made in 1979 and 1980, so you might be off a decade on the year model. Koyker makes a lot of loaders for Yanmars, although they do not list one for the 195, I suspect they have one that would fit. Perhaps someone that is more knowledgable on the 2-cylinder Yanmars could figure out which mount kit would fit. They have 3-point backhoes as well, but an operator must be careful on three-point hoes not to get carried away or you could damage the tractor. Subframe mounts are best, but are not available for all models.
   / YM 195D #3
the 195 and 240's are close in size to the 1700, if anyone knows which mounts those take, it would at least be a start.
Soundguy
   / YM 195D #4
The YM1700, 1900 and 2000 all take a 110 Koyker loader and mount kit K665769, hose kit K665254. This should work on the 195 with little or no modification. Thanks Soundguy for the info on size. Dave
   / YM 195D #5
The Kelly DL1000 loader will fit on the YM195 nicely. It would require drilling 4 holes in the lower mounting bracket. 4' or 5' bucket available which is sized for the size of the tractor. I feel the Koyker uses to large of a bucket for the smaller tractors. The Kelley B650 backhoe would also be a good match for the YM195. contact me for pricing with a 20% discount. 1980 is closer to the true year.
3000 GAL  SELF CONTAINED FUEL SKID (A52472)
3000 GAL SELF...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
