YM 186D replacing seal behind brake drum.
   / YM 186D replacing seal behind brake drum. #1
Yanmar186d
Melbourne Australia
Yanmar 186D
Hi to everyone, I'm replacing my brake shoes on the 186D and found one side had a lot of oil in there, I have removed the drum and found a plate there with 6 or so bolts and removed them, I noticed the plate has 2 threaded holes to put 2 bolts onto so to push the plate out but It's very tight and I'm worried ill brake it,
Am I doing something wrong or is there something else I need to do?
Thanks
Daniel.
   / YM 186D replacing seal behind brake drum. #2
I don't think you can pull that off without taking more apart internal. There is a differential and bevel gear on those shafts. You can probably pop out the oil seal and change without taking the housing out.
   / YM 186D replacing seal behind brake drum. #3
   / YM 186D replacing seal behind brake drum. #4
Make sure you have the Dia. Seal or the correct one the best you can tell and pry the old one out. Then just tap the New one back in. A good old screw driver my do the job.
Winston I did what you said, by removing the c clip I got the seal out with a screw driver, once the seal is out the whole shaft pulls out with no force ready to clean and reinstall with new seal.
Thanks to all for the advice.
   / YM 186D replacing seal behind brake drum. #6
Yeah it is a little pitted with rust and have given it a light sand to clean it up and I'll see how it goes when I fit it back on. Thanks
Cheers
Daniel
   / YM 186D replacing seal behind brake drum. #8
good to see it was easy to remove
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
2016 INTERNATIONAL PROSTAR (A52472)
2016 INTERNATIONAL...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
